I didn't know ripple was an AC noise on a DC reference
Think of it like waves on the surface of a swimming pool. The depth of the pool is the DC voltage, the variation at the top is like AC, but on top of the DC.
I thought ripple was an AC waveform that looked like a sawtooth waveform riding on a DC reference
Ripple is normally the name given to a noise source that is regular and repetitive and predictable. In this case you know that 120 times a second it will reach a peak in some manner and then fall back to a trough in some (possibly different) manner. And you know it's going to happen roughly the same next time. It may vary with load, etc., but it's a regular waveform at a given operating point.
Or what other types of AC ripple is there?
It's useful to differentiate ripple (which is a regular signal) from random noise. Random noise is a variation in the output signal that is not predictable in any other way than by talking about averages. You might note that it has an average RMS voltage of some voltage, but you cannot tell from instant to instant what the actual voltage will be.
Other sources of noise are distinguished by their origin. For example if you noted a signal at 990kHz, and the amplitude looked noisy, but the bandwidth of the signal was very narrow, you might well wonder if you had a nearby AM radio station transmitting at 990 on the AM dial. You would call this RF interference, because you know the source of it.
You might notice spikes of noise that correspond to turning a large electrical appliance off and on. This may be transmitted through the mains, and so that is mains borne interference.
There are all sorts of noise sources. If you are really dedicated you could include:
- Thermal
- Shot
- Flicker
- Inter-modulation
- Crosstalk
- Impulse
- Interference
- Burst
- Avalanche
- Industrial
- Atmospheric
- Solar
- Cosmic
...and probably others
In most cases you're interested in the dominant sources (and in your case Solar and Cosmic noise are unlikely to feature heavily)
