Measure water level using IR or Ultrasonic sensor
Discussion in 'Sensors and Actuators' started by sahan hasitha, Jan 7, 2016.
  1. sahan hasitha
    sahan hasitha
    5
    Jan 7, 2016
    Hello guys. I want to measure water level for my project. I have used ultrasonic distance sensor to measure water level. its working fine but the sensors are not water proof. It may damage because of water. Now um going to measure the level using Sharp GP2Y0A02YK0F IR sensor. But i dont know its possible or not. Tell your ideas about measuring water level with that sensor. Tell me if you have any other idea to measure the level electronically.
    Thank you
  2. Harald Kapp
    9,543
    1,969
    You'lll have to give it a try.
    The datasheet states some caveats:
    1. The lens of this device needs to be kept clean. There are cases that dust, water or oil and so on deteriorate the characteristics of this device. Please consider in actual application.
    2. Distance to a mirror reflector can not be sometimes measured exactly - my comment: the surface of watermay act in a mirror-like fashion.
  3. Bluejets
    Bluejets
    3,684
    757
    Oct 5, 2014
    Pressure sensor.....
  4. sahan hasitha
    sahan hasitha
    5
    Jan 7, 2016
    So if the water touches on sensors, it may give a wrong output of water level. So i have to do this with another method
  5. sahan hasitha
    sahan hasitha
    5
    Jan 7, 2016
    Ah great idea. I ll try it. Thank you buddy
  6. Ford5of5
    Ford5of5
    11
    Jan 8, 2016
    would a float switch be out of the question?
