Measure spindle speed with a Multimeter???
Discussion in 'General Electronics Discussion' started by Les Fackrell, Nov 26, 2016.
  1. Les Fackrell
    Les Fackrell
    Nov 26, 2016
    I am in the market for a replacement multimeter and I have noticed that some have a frequency counter. This made me wonder if a simple circuit using a light dependent resistor, some shiny sticky tape and a battery would make a signal that the meter could Count? If the reflective tape were stuck on the spindle and a light shone on it, the LDR would change its resistance depending on the reflected light. Would this make a signal that the meter would pick up?
    You will probably guess that I am a complete novice in electronics. (I am aware that you can buy a tachometer cheap as chips on Ebay but I just wondered)
    Les
  2. Bluejets
    Bluejets
    4,985
    1,045
    Oct 5, 2014
    Think you will find it requires a changing voltage.
    A hall effect (A3144), magnet, collector resistor and a battery should work.
    Take the signal from collector to ground.
  3. Alec_t
    Alec_t
    2,970
    805
    Jul 7, 2015
    LDRs are rather sluggish, so you would get unreliable results at high spindle speeds.
    (*steve*) likes this.
  4. (*steve*)
    25,497
    2,839
    If you wanted to go with an optical solution, an opto-transistor would be a better bet.
    Some problems you might have to deal with are ambient light levels, 2 x mains frequency flickering of lights, and enduring you get enough light to the sensor.
    Some form of chopper that interrupts a light source pointing directly at the sensor may be better if you can achieve it.
  5. CDRIVE
    4,960
    652
    May 8, 2012
    Does your spindle have any ferrous gears or other ferrous protrusions?
    Chris
  6. Nico Orru
    Nico Orru
    Jun 7, 2017
    I have obtained reasonably accurate results:
    - gluing a tiny neodymium magnet to a broken bit
    - wiring up a U18 hall sensor (latching, but should not be necessary)
    - using an oscilloscope with frequency meter to read the result. You can probably achieve the same by using a multimeter (with freq.meter) instead.
  7. FuZZ1L0G1C
    FuZZ1L0G1C
    368
    118
    Mar 25, 2014
    Many DMM's these days have built-in frequency measurement.
    Found (on Major-Tech and Top-Tronic DMM's) that they read sinewaves more reliably than square (maybe as square contains harmonics*).
    Also, according to their own manuals, voltage level should be at least 10V RMS AC.
    * Reads the fundamental of square-wave, but 'hunts' up & down as well.
