Measure battery voltage while charging
Makemyday
Nov 1, 2017
Nov 1, 2017
hello! Does anyone know how to measure battery voltage while charging? Does it needed an IC or i just need to cut the power then measure the battery then turn it on again.. Thank you!
Makemyday
Nov 1, 2017
Nov 1, 2017
Im want to use tp4056 charging circuit. I found out that it has a chip enable pin.. Is it safe to disable the chip every 10mins just to read the battery voltage. Then turn it on again to continue charging.
Harald Kapp
13,722
13,722
It is safe, yes, but not economical. The datasheet I found is unspecific as to the charging algorithm, but the charge cycle diagram implies a pre-charge time of approx. 8 min - 10 min before charge with constant current starts. Therefore interrupting the charge cycle every 10 minutes will leave very little time for charging as most of the time is spent in the pre-charge cycle.
You'd have to make the interval much longer, e.g. at least every 30 minutes.
Why do you want to measure the battery voltage at all? The TPS4056 has a built-in constant voltage limit of 4.2 V and has two charge state output pins which you can evaluate to indicate charge status.
