Meaning of BATERRY polarity
lefam
Nov 18, 2010
43
Nov 18, 2010
43
Hi guys!
I am pretty new to electronics. I am having some problems with my first circuits and I am now suspecting that maybe my understanding of battery polarity is wrong.
So, my question is: in batteries (example 9V alkaline) the (+) terminal is +Vs, and the (-) terminal is GROUND?
(+) terminal = +Vcc?
(-) terminal = GROUND?
I have been using (-) like +Vs and (+) like GROUND. Probably the cause of failure in my first circuits.
davenn
14,264
14,264
Hi guys!
why would you have even considered connecting the - to the + ?? thats not logical :confused:
+ to + and - to - always
reversing the polarity of the power if a surefire way of killing the intergrated circuits etc
(-) terminal = GROUND?.
No ( - ) terminal = Negative, always call ( - ) the Negative terminal, see next comments
Negative ( - ) would normally be Ground (tho there are some exceptions)
you would usually only see a Ground label if the ( - ) part of the circuit was connect to the chassis of the equip, which was then connected to ground via the "earth" (ground) lead of the mains power lead.
cheers
lefam
Nov 18, 2010
43
Nov 18, 2010
43
To power a circuit (for example the 555 IC), what should I connect where they ask for +Vs (PIN8 in the case of the 555 IC)? The (+) terminal from the battery or the (-) terminal?
davenn
14,264
14,264
after reading my comments in previous post... what do you think the LOGICAL connections would be ? :)
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
As davenn says, the "+" is a clue.
+ to +
- to -
so + to +Vs is obvious
Now, some circuits require +, - and 0v, in which case you need 2 batteries, but I won't even confuse you with that just yet.
lefam
Nov 18, 2010
43
Nov 18, 2010
43
So, that's why my circuits where not working (because of using - terminal as +V). I tried to build a 555 LED flasher and it was not working. I failed also with transistor circuits.
Now my transistor circuits are working.
I have one curiosity: why do the electrons flow from the (+) terminal to (-) in the battery? Are they following the conventional flow? I am confused because in electron flow (the real flow) electrons flow from (-) to (+). What is the meaning of polarity of batteries?
davenn
14,264
14,264
Electrons flow from Negative to Positive that is the "real" electron current flow.
electrons have a negative charge.
The positive to negative is what is called conventional current flow ( its misleading)
Polarities of a battery ( or any other supply) well you have to have a positive and a negative. you cannot have 2 negative terminals (or 2 positive terminals) ... there would be no resulting current flow.
davenn
14,264
14,264
+ to +
- to -
yeah we will leave split supplies to another day haha ;)
hopefully he is finally sorted out for a single rail supply :)
Laplace
Apr 4, 2010
1,252
Apr 4, 2010
1,252
Don't get too concerned about the flow of electrons. For all practical circuit analysis and design purposes, just assume that current flows from plus to minus. About the only time you will need to consider electrons is in the study of quantum electronics and the physics of the P-N junction between doped semiconductors where you will mathematically model the flow of electrons and the flow of holes (i.e., the presence of absence.) And never connect the minus (-) power supply terminal to the +Vcc pin of your IC.
lefam
Nov 18, 2010
43
Nov 18, 2010
43
So in a battery, the (+) terminal is the most negative terminal (with excess electrons) that flow to (-) (lack of electrons)?
Do the batteries use conventional flow in the terminal indicators?
(*steve*)
25,510
25,510
No, the + terminal is + and the - terminal is -
FORGET about current flow, conventional or otherwise.
Just connect the positive on the battery to the positive supply rail of your circuit, and the negative to the negative supply rail.
It's really that simple. there are no tricks.
Laplace
Apr 4, 2010
1,252
Apr 4, 2010
1,252
@lefam: "So in a battery, ....."
It is not useful to think about what happens in a battery because then you have to think about electrons and how electrons behave in terms of chemistry. That is a chemistry issue, not an electronics issue. Focus your attention not on the battery but on the circuit to which you connect the battery. Now, you may question why I assume that current flows from plus to minus in a circuit, especially since it would be equally valid to assume the reverse. I am a member of the cult of positive flow because virtually everyone else is also a member of the positive cult. Can you imagine the level of cognitive dissonance if believers for positive flow had to work together on a project with believers for negative flow? That is too horrible to contemplate!
