MCP73834 and leds
Discussion in 'Electronic Design' started by Marco Trapanese, Apr 6, 2013.
  1. Hi,
    MCP73834, here the ds:
    http://ww1.microchip.com/downloads/en/DeviceDoc/22005b.pdf
    page 17, table 5-1.
    Standard hook-up. 10k on therm pin to gnd.
    When I power the IC without inserting a battery both leds turn on (=
    system test mode). The ds says:
    "The system test mode is entered by driving the THERM
    input greater than (VDD-100 mV) with no battery
    connected to the output."
    There is no battery connected, indeed, but the THERM input is
    pulled-down with the 10k resistor. So how could the 73834 enter is such
    a state?
    Marco
  2. Il 06/04/2013 19:42, Jim Thompson ha scritto:
    5V
    Marco
  3. Il 06/04/2013 21:51, Jim Thompson ha scritto:
    Thank you very much!
    What's the bottom line, then?
    I mean, the LTVT signal will be always high, no matter the presence of
    the battery.
    I'm afraid about the charging: no problem (I guess) if it enters the
    system test mode without the bat, but I'd like it will charge it...
    Marco
  4. Il 07/04/2013 18:24, Jim Thompson ha scritto:
    It seems it works... in the afternoon I charged a Li-Ion battery at very
    low current (about 250 mA). After few hours the end-of-charge led lit
    up, eventually.
    Marco
