mc68332 embedded programming problems
Discussion in 'Electronic Design' started by [email protected], Apr 26, 2006.
  1. Guest
    Hi all,
    I am trying very unsuccessfully to load my code from my Flash into ram,
    and then jump to ram. I am finding 2 issues:
    1. I can only load so many bytes to ram before the system resets.
    2. when i make a jump to the code in ramspace, the chip wanders off
    and gets lost, not knowing where it is going. I have examined ram
    memory through the bdm port, and I find that the instructions are there
    just before the jump, but it hangs up when I jump.
    Any help would be greatly appreciated.
    Rob McPherson
  2. This is not understood. Why does the system reset ?
    Is there a watchdog ?
    Yes, this stuff is tricky. Consider interrupts,
    consider the stack, what code is loaded to RAM ?
    Was the code linked to run at the specified location ?
    With absolute or relative jumps within the code ?
    Are there segment registers ?
    Rene
  3. Guest
    Well, I fixed the first problem, it being a watchdog issue. Sorry
    about that part. The second is still an issue. Any help would be
    Rob McPherson
