Y
Yannick
I made a pcb for the mc100el1648, i used the schematic described in
the datasheet to get a sine wave output (datasheet page 10 figure 13).
All components are smd, decoupling of every dc voltage with 68nF caps,
short tracks and opening in gnd plane around tank circuit to reduce
parasitic capacitance to gnd.
Tank circuit exist of 56nH coil (smd) and varicaps are 3-40pF range.
power supply betzeen 0 and 5V. Still i can't get it to work, the
output had dc shift of 3.3V but the ac signal is crap, it is very
noise, a lot of higher harmonics (ni nice sine wave) , pk-pk is 80mV
and frequency is about 60Mhz independed of varicap voltage. I tried
different loads on the output (from none to 50-100ohm termination) but
without a significant difference.
I am wondering i perhaps blew up the device by accidently putting one
of the varicaps in forward bias, is this possible or is the devide
robust enough in this regard?
Anyone an idea of what could be wrong here? Thanks,
Yannick
Yannick
