Maximum Voltage in passive capacitive circuit
Discussion in 'General Electronics Discussion' started by fsonnichsen, Apr 17, 2019.
  1. fsonnichsen
    fsonnichsen
    8
    Oct 23, 2013
    This question is academic insofar as I am assuming a circuit with no inductance.
    In a circuit having only passive capacitive elements, when driven with a square wave--is it possible to have a voltage greater than the drive voltage at any node? I am assuming linear components--e.g. no diodes or active elements--just a capacitor and resistor network.
    From an energy perspective I think not. Overshoot from "ringing" for example, always (in my experience) is associated with inductances and a 2nd order circuit.
    Fritz
  2. duke37
    duke37
    5,211
    718
    Jan 9, 2011
    I have seen an oscillator circuit many years ago which had a string of capacitors, base to earth. The junctions between the capacitors were driven with resistors from the emitter. A very low increase in voltage was obtained, sufficient to promote oscillation. The frequency was low and was used for vibrato modulation in an electronic organ.
  3. AnalogKid
    AnalogKid
    2,297
    646
    Jun 10, 2015
    Sounds like a phase-shift oscillator.
    ak
  4. AnalogKid
    AnalogKid
    2,297
    646
    Jun 10, 2015
    If I understand the question correctly, then yes, it is.
    5 V square wave, 50/50 duty cycle, 0 ohm source impedance, 1 kHz. positive pulse width = 500 us
    0.1 uF capacitor and 1.667K resistor in series; time constant = 166 us
    Cap connected to square wave source, resistor tied to +5 V.
    The pulse width is three time constants, so when the square wave is low for 500 us, the cap is charged to 95% of Vcc. When the squarewave goes high, the R-C node jumps up to 9.75 V and then starts decaying down to 5 V. As the C gets larger, the R-C node looks more and more like the input squarewave, now centered about 5.0 V (2.5 V to 7.5 V) by simple AC coupling.
    ak
  5. Ratch
    Ratch
    1,042
    306
    Mar 10, 2013
    The following is a passive circuit that contains only capacitance and resistance. No overshoot and no ringing. The output is at zero phase with respect to the input at a particular frequency, and the voltage gain is enough to insure enough feedback to make an oscillator. The transfer function is
    and the frequency at which the output phase with respect to the input phase is zero is
    The magnitude increase at the zero phase frequency is 30/29 = 1.03%.
    The following shows the circuit with C = 1uF, R = 1k, and AC voltage at 390 Hz. Comparing the output probe with the input probe displays shows a very slight increase in peak to peak amplitude.
    Ratch
  6. Ratch
    Ratch
    1,042
    306
    Mar 10, 2013
    Not quite. The RC network actually increases the voltage at a zero phase shift.
    Ratch
  7. AnalogKid
    AnalogKid
    2,297
    646
    Jun 10, 2015
    Not sure how you can say that. I was winging a guess based on an incomplete, two-sentence description with no schematic. Based on only that, a string of resistors and capacitors and one transistor still sounds like a phase shift oscillator to me.
    ak
    [​IMG]
  8. WHONOES
    WHONOES
    661
    134
    May 20, 2017
    Being a little pedantic, a circuit without inductance does not exist. That is also true of capacitance.
  9. Ratch
    Ratch
    1,042
    306
    Mar 10, 2013
    The circuit above is really a phase shift oscillator. The 3 caps and resistors shift the phase 180°. The loss of voltage across the 3 RC network is compensated by the voltage gain of the common emitter transistor.
    The circuit presented by me has no phase shift and actually amplifies the input voltage slightly. That means it can be used in a common collector transistor configuration which, as you know, never exceeds unity voltage gain and has no phase shift. Therefore, I consider it wrong to call an oscillator incorporating my network a "phase shifter" because it does not shift phase.
    Ratch
  10. Ratch
    Ratch
    1,042
    306
    Mar 10, 2013
    The difference is that the stray inductance present is mostly compensated for when necessary and rarely used as a primary component in the circuit design.
    Ratch
  11. AnalogKid
    AnalogKid
    2,297
    646
    Jun 10, 2015
    Ah, but in #3 I was not commenting on your circuit, which had not yet been posted. That is why I quoted the OP.
    ak
  12. Ratch
    Ratch
    1,042
    306
    Mar 10, 2013
    OK, I see your point. I should not have commented on your observation. I think we both agree my circuit is not a phase shifter.
    Ratch
  13. Audioguru
    Audioguru
    2,568
    578
    Sep 24, 2016
    A voltage multiplier circuit is passive and boosts the voltage. The diodes are passive.
  14. Ratch
    Ratch
    1,042
    306
    Mar 10, 2013
    But not in a linear manner like a voltage amplifier or transformer does.
    Ratch
  15. The Electrician
    The Electrician
    111
    10
    Jul 6, 2012
  16. Ratch
    Ratch
    1,042
    306
    Mar 10, 2013
    The IEEE references are useless to anyone who does not live close to a library that racks that 1951 journal, or is not a member of IEEE.
    The circuit in stack exchange does not have a phase shift of zero degrees when its gain is greater than 1. That makes it less useful. Tell me if I am wrong.
    Ratch
  17. The Electrician
    The Electrician
    111
    10
    Jul 6, 2012
  18. Ratch
    Ratch
    1,042
    306
    Mar 10, 2013
    Interesting article. It is going to take some time to study. Those guys had to work out those equations by hand. Lots of work involved. Also of interest are some of the advertised components that are no longer available or rarely found, like multi-section capacitors.
    Ratch
  19. AnalogKid
    AnalogKid
    2,297
    646
    Jun 10, 2015
    I'll tell you I don't understand why that matters. There is nothing in post #1 about phase shift being part of the question or answer. also, *any* circuit with nothing but Rs and Cs will have phase shift. That's kind of a thing.
    The StackEx circuit and the single-stage version I described in #4 are lossy charge pumps. Seems simple enough.
    Note, I think the OP has abandoned this thread.
    ak
  20. WHONOES
    WHONOES
    661
    134
    May 20, 2017
    Agreed. But stray capacitance can make itself felt and is not so easy to ignore.
