Maximum voltage generated by a function generator
Discussion in 'General Electronics Discussion' started by Emam, Oct 3, 2014.
  1. Emam
    Emam
    63
    4
    Jul 7, 2014
    Hello,
    I have a very basic question (since I am not familiar with generators !).
    I would like to buy an arbitrary function generator (like Agilent 33210A).
    In the data sheet of this generator its written that the generated voltage is 10 Vpp for 50 ohm charge résistance.
    So, I want to know if I connect a very larger resistance (such as 8 Mega ohm) to this generator, what will happen? Can I have for ex a square pulse of 7 Volt amplitude on my resistance?
    Because I mean do they have a something like "current regulators" inside?
    Thank you for your help
  2. BobK
    7,682
    1,688
    I think what it means is that the voltage is 10V with an internal resistance of 50 Ohms. If you measure it with a 1M probe it would read 10V. If you put a 50 Ohm resistor across the output, the voltage would be cut exactly in half.
  3. hexreader
    hexreader
    126
    38
    Apr 21, 2011
    From the manual:
    Amplitude
    Range 10 mVpp to 10 Vpp into 50 Ω
    20 mVpp to 20 Vpp into open circuit
    Imagine the generator as providing +/- 10 Volts at maximum output, then imagine that there is an internal 50 Ohm resistor in series with the output connector. The ideal load would have 50 Ohms impedance, which is why terminated voltage is half of the open circuit voltage. The 50 Ohms internal impedance and the 50 Ohm load impedance work as a voltage divider to halve the output voltage.
    8 Megohm load will barely drop the voltage at all. It is close to open circuit compared to the 50 Ohm Function Generator impedance.
    If you want 7V across your 8 Megohm load, simply set the Function generator output to that (open circuit) value.
