maximize efficiency of a solar panel charging a Li-Ion battery
Discussion in 'Power Electronics' started by Cosmin3, Nov 4, 2018.
  1. Chemelec
    Chemelec
    291
    47
    Jul 12, 2016
    I doubt your Solar panel has Enough Output Current.
    When you Step up the Voltage, The Output Current Goes LOWER.
    And When you apply a Load that Draws More Current than is Available, Than the Voltage will DROP Even LOWER.
  2. Cosmin3
    Cosmin3
    15
    Aug 16, 2018
    This is the answer I was looking for.
  3. (*steve*)
    25,361
    2,756
    Sorry, I thought I mentioned that in post #9.
  4. Cosmin3
    Cosmin3
    15
    Aug 16, 2018
    Sorry, you're right.
    An example of an working circuit would of helped.
    But it was my fault by not making the connection "not MMPT controlled" >> "MPPT".
    I wonder if there are other similar circuits in this power "range". Searching on Google I found only for higher/lower...
