Maxim/Dallas DS80C400 or Freescale MC9S12NE64
Discussion in 'Electronic Design' started by Sylvain Munaut, Sep 28, 2004.
  1. Hi,
    Any one has experience with any of theses ?
    [Maxim/Dallas DS80C400] or [Freescale MC9S12NE64]
    They are both small uC with integrated ethernet.
    The pro/con I see:
    Pros:
    - Powerfull ROM embedded that has full TCP/IP stack
    - Can TFTP boot from network (so No need of programmation tool)
    Cons:
    - Need external ethernet PHY
    - Need external SRAM (to download program)
    - (so take up more space ...)
    - Runs at 75Mhz max but has 4clock/machine cycles.
    Pros:
    - Runs at 25Mhz but 1clock/machine cycles (not sure but it seems)
    - Has integrated ethernet PHY
    - No need of SRAM if the application don't require it ...
    Cons:
    - Flash based with no firmware, so need special programmation tools
    - The TCP/IP stack seems weird.
    The application is a small smart card terminal with really low ethernet traffic and
    pretty simple behavior.
    Sylvain
