max milliamps ribbon cable
Discussion in 'General Electronics Discussion' started by qweets, Jan 15, 2011.
  1. qweets
    qweets
    48
    Sep 26, 2010
    hello
    i am going to try and use a ribbon cable off my next pcb to connect the main board to a display panel of 24 leds. I wonder what the maximum milliamps would be using two cores of a 26 way ribbon cable (- +) so that i may power them? Or would it definitely be better to use a separate power cable to connect the 5v from the main board to the display panel?
    thanks for advice. : )
  2. jerryg50
    jerryg50
    57
    Apr 18, 2010
    The amount of current carry capability is dependent on the gauge of the conductors in the ribbon cable, the length of the cable, and the ratings of the connector types.
    I suggest you contact the manufacture or supplier of the ribbon cable to find out its specs.
    Jerry G.
  3. qweets
    qweets
    48
    Sep 26, 2010
    thanks jerry : )
