Matrix circuit for Keypads
Discussion in 'Microcontrollers, Programming and IoT' started by pyro009, Feb 19, 2013.
  1. pyro009
    pyro009
    Feb 19, 2013
    In a recent embedded systems class we were briefed on the addressing mechanism of a matrix keypad. The keypad we used is a 2x2 keypad for 4 buttons.
    My question is, why not use a 1x4 keypad? wont it reduce the no. of lines ?
  2. Harald Kapp
    11,446
    2,628
    No, it won't.
    1x4 keypad: 1 common + 1 line per key (4) = total 5
    2x2 keypad: 2 rows+2 columns = total 4
    With 4 keys on the keypad, the difference may not be worth the effort of multiplexing the matrix - unless you run out of port pins of the microcontroller.
    The example given to you was probably only to explain the principle.
    Consider a 64 key keypad: The ratio then is 65 lines vs. 16 lines (8 rows, 8 columns).
    You see?
  3. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    In the case of a 4-button keypad, arranged as 4x1, there's no need for an I/O pin to drive the "1". It can just be tied to ground, and only 4 inputs are needed. So it works out the same. But as Harald said, the principle applies to keypads with more buttons. A keypad with 6 buttons or more will require less I/O if it's multiplexed.
  4. donkey
    donkey
    1,293
    56
    Feb 26, 2011
    hey kris why woldn't the 1 key need an I/O pin? every switch needs 2 connections, 1 ground and 1 other. if button 1 doesn't have a ground then how does it work?
    just trying to figure this out in my head thats all I just can't see it having less than 5 ifin a single row
  5. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Micro pin pulled high ---- button --- Ground
    No need to matrix toggle the ground pin in a 4x1 arraignment...
  6. donkey
    donkey
    1,293
    56
    Feb 26, 2011
    ok.... that doesn't help I will figure it out eventually but thanks coca for putting me on the path to find out how to do it
  7. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Look at the attached photo, it's reverse logic of what we were talking but the same truths hold...
    As you see in a 4x2 matrix you check the keys like this...
    All rows input
    Both columns logic 0
    Toggle column one to logic 1
    Scan Row 1-4 to see if any of them are pressed
    Toggle column one back to logic 0
    Toggle column two to logic 1
    Loop
    Thus you need the columns tied to I/O lines so that can change their state as you progress across them while scanning...
    But in a 4x1 matrix you never need to toggle the column to scan all the keys, just tie column one to logic 1 permanently, no need to use an I/O line to do this as there is no progression across the columns as there is only one...
    [​IMG]
  8. donkey
    donkey
    1,293
    56
    Feb 26, 2011
    ok coca let me put it this way, while trying to reformat an sd card for my computer I formatted the wrong drive and lost 2 terrabytes of info..... and to top that off when I got the thing formattedsomethingwentwrong andnowI cant find the sdcard.... can you tell my mind is kinda not with it today? lol
  9. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    If you just formatted the drive the data is 100% recoverable without much hassle, you just need to rebuild the file index (if it was a quick format) or you recover the files to another drive and build a new index if it was a full format, there are plenty of programs to do this, some freeware... That is unless you tampered with it further...
  10. donkey
    donkey
    1,293
    56
    Feb 26, 2011
    yeah i know that but is it worth the effort? lol I am trying to get this freaking sd card fixed at the same time and no go.. anyway I hijacked a threadwhich I hate doing I will move this to off topics
  11. pyro009
    pyro009
    Feb 19, 2013
    Thanks guys. Appreciate the help
