Matlab Rayleigh Fading Channel Simulation?
Discussion in 'Electronic Basics' started by Davy, Mar 6, 2006.
  1. Davy
    Davy Guest
    Hi all,
    I have got a Rayleigh Fading Channel Simulation code by Matlab.
    The code list below:
    % Rayleigh fading
    a = sqrt(0.5)*( randn( 1, symbols_per_frame) + j*randn( 1,
    symbols_per_frame) );
    % complex noise
    noise = sqrt(variance)*( randn(1,symbols_per_frame) +
    j*randn(1,symbols_per_frame) );
    % in all
    code_fade = a.*code + noise;
    Is the code right? If not right, how to modify it?
    Best regards,
    Davy
  2. Guest
    Yes, it is perfectly right.
    Generally, we assume coherent system, so the phase is perfectly
    estimated. hence the phase of the fading constant can be neglected.
    -SaiRamesh.
  3. James G.
    James G. Guest
    Davy, you seem to assume that there is no correlation in temporal and
    frequency domains, don't you?
  4. Davy
    Davy Guest
    Yes, there is no correlation in temporal and frequency domains.
    I have read the Probability book. The frequency shift is uniformly
    distribution. And the fading is Rayleigh distribution.
    Thanks!
    Davy
  5. Guest
    Yes, the phase has uniform distribution and the magnitude is
    Rayleigh distributed.
    I have a question assuming coherent BPSK transmission
    y=hx+n; where h is a real no whose pdf is Rayleigh. Neglecting the
    phase is a correct assumption?
    -Regards,
    -SaiRamesh.
