Mathcad question: Please graph (Y1 + Y2 = 1/Zo) over range of Y1 and Y2 .( NOT OT).
Discussion in 'Electronic Design' started by Teece, Feb 20, 2007.
  1. Teece
    Teece Guest
    I don't know why I am having so much trouble trying to graph this simple
    function in Mathcad. It is not Off Topic because, ultimately, I am trying to
    graph the solutions to the Thevenin Termination problem (split termination,
    if you prefer).
    Specifically, if I have two admittances, Y1 and Y2, in parallel, they add. A
    termination admittance would result from Y1 + Y2 = 1/Zo. It is easy to plug
    in a few numbers and get some values for Y1 and Y2 that satisfy, say Zo=50
    Ohms. I am trying to get a graph of the function in Mathcad, as in Y1 vs Y2
    for some value of Zo, and for some reason, it is just not coming to me.
    I know that there are lots of Mathcad gurus out there that will find this
    really easy.
    Thank You
    Tom
  2. Graphing generally requires a range variable that produces a
    lits of values (as in x:1;10). You can either make the
    values to be graphed functions of x or graph a function of x
    against the xalues of x, itself.
  3. Rich Webb
    Rich Webb Guest
    Using your example, define Zo:=50 and then define the function
    Y2(x):=(1/Zo)-x. Drop a graph on the page with @ and just fill in the
    marker for the left axis with "Y2(x)". Mathcad will give you a default
    range for the x-axis but you can change that, as usual, with the axis
    limit boxes.
    You may, but are not required to, pre-define a range for the independent
    variable as in x:=0..10 or x:=0,0.1..10 and so forth. The "y-axis only"
    trick works with all functions, built-in and user-defined.
  4. Teece
    Teece Guest
    It worked fine.
    Regards
    Tom
