Math for led calculations
Discussion in 'LEDs and Optoelectronics' started by conntaxman, Mar 12, 2013.
  1. conntaxman
    conntaxman
    89
    Jun 17, 2011
    Im tring to figure out how to do the math for using it in a cir.here's what it is.
    http://www.mouser.com/ds/2/389/CD00156614-115578.pdf
    The Current setting. ----FOR A ----stcs1phr
    The current is set with an external sensing resistor connected to the FB pin. The feedback
    voltage is 100 mV, then a low resistor value can be chosen reducing power dissipation. A
    value between 1 mA and 1.5 A can be set according to the resistor value, the resulting
    output current has a tolerance of ± 10 %.
    For instance, should one need a 700 mA LEDs current, R
    F
    should be selected according to
    the following equation:
    RF=VFB/ILEDS=100MV/700MA=142MΩ
    here is the spec for a 10watt led that im going to use.
    and power it by a 12 car battery.[VF]9-12 [IF]1000MA
    To figure the amps out is it 12 divied by 1000 =.012
    what dose RF AND VFB,I think vfb = forward voltage ,
    don't know what RF stands for.
    tks
    John
  2. BobK
    7,682
    1,688
    Feedback resistor. You need to choose a resistor that drops 100mV at the desired current. At 1000mA that would be
    V = I R
    0.1 = 1 R or R = .1 Ohm
  3. duke37
    duke37
    5,364
    771
    Jan 9, 2011
    100MV at 700MA is quite enormous. Do you have your own generating station!
    I do not follow your calculations. I do not see what current your leds take, perhaps it is 1A, The feedback resistor has to give 100mV. R = V/I = 0.1/1 = 0.1ohm.
    Rfb = Feedback resistance
    Vfb = Feedback voltage
    RF = radio frequency
  4. BobK
    7,682
    1,688
    MV = Megavolts mV = millivolts
    MA = Megamps mA = milliamps
    What's 9 orders of magnitude between friends?
Similar Threads
Loading...
