Markings on mil-spec fusible resistors?
Discussion in 'Electronic Components' started by [email protected], Jun 20, 2005.
  1. Guest
    I'm looking at some resistors in a old piece of mil-spec equipment and
    I think that they're supposed to be fusible (e.g. fail open, not
    shorted). They look like metal film 1/2W resistors, body is painted a
    bluish gray, and are marked, for example, red-purple-gold-gold-white.
    It seems to be a 2.7 ohm 5% resistor. Am I correct that the last
    (white) stripe indicates that they are fusible? Or is this some
    mil-spec quality stripe?
    Tim.
  2. Guest
    Yes you are correct Tim.
  3. Tim Shoppa
    Tim Shoppa Guest
    Am I correct that the last(white) stripe indicates that they
    As in the SNL skit, "it's a floor wax AND a dessert topping!"
    Tim.
  4. truegridtz
    truegridtz Guest
    Tim, this appears to be a mil-spec designator for solderable leads on a RL20
    (mil-r-22684) 1/2 watt metal film. They are very good resistors. This
    milspec was superceeded by RLR (mil-r-39017) which is the same part, but put
    through a tighter quality control. Mark
