That's it CW....put it on the artwork....that way its etched in!......Ross
The guy wants serializations. Who is going to pay the tooling
charge for each new gerber setup? Certainly not the PCB house.
One can place a "pad" on the board. A rectangular area of reference
designator silk screen area that marks the location for placement of
a high temperature serial number label.
Put conformal coat over that (the varnish types) to set up the ID.
Hell, any label under varnish will do, if it isn't going back into
the reflow oven. That is... if it is an SMT design. The high temp
labels are cool though, and quite resilient. The conformal coating
guarantees non tampering if put down with a high gloss look.
(Dolph's AC-41) Don't allow access to the varnish can, of course.
Don't mention anything about solvents.
One can also encode the edge of the PCB with a file for quite a
large number count. Four edges allows for a nice matrix, depending on
the size of the board. One could encode thousands of serializations
in that manner. Triangle file... small notches, no intrusion into any
conductors or power planes, of course. The same varnish will seal the
edges of the PCB to prevent tampering with that form of coding.
If he is the only one that knows the coding scheme, he could keep
them honest.
