Manufacturer' models in separate directories in LTspice.
Discussion in 'Electronic Design' started by Fred Abse, Jun 30, 2013.
  1. Fred Abse
    Fred Abse Guest
    A while ago somebody was inquiring about putting manufacturers' files in
    dedicated directories. Might have been josephkk, or George Herold, I can't
    remember.
    The only way I have found to do it is to put manufacturer directories as
    subdirectories of /lib/sub.
    You call them with ".lib <Manufacturer\modelfile>"
    Like ".lib Zetex\ZTX415.sub"
  2. Fred Abse
    Fred Abse Guest
    Quite so. However it's tedious, and isn't easy on a Linux system. I don't
    use Windows at all. It's bad enough having to remember use even one
    backslash as a directory delineator..
    Full path to my models is:
    /home/fred/.wine/drive_c/Program\ Files/LTC/LTspiceIV/lib/sub/<manufacturer>
    Case sensitive.
    That shows what I'm accustomed to using backslashes for ;-)
  3. josephkk
    josephkk Guest
    Thanks fellers. There is so many little things like these to know.
  4. Fred Abse
    Fred Abse Guest
    Another little wrinkle I might try is to put the manufacturer
    subdirectories in as symlinks to subdirectories of my general "Components"
    directory, where I keep datasheets, etc. which is organized by
    manufacturer already and centralize everything.
    Only would work in 'nix. I run three different spice versions, so it might
    be a good idea.
