malfunctioning headphone jack, hp laptop
Discussion in 'Electronic Repair' started by Jess, Nov 29, 2005.
  1. Jess
    Jess Guest
    I have an hp laptop, and I have recently noticed that the headphone
    jack doesn't work. I hear no sound when I plug in headphones. The
    speakers do however work. Does anyone have an idea what the problem may
    be or how I could fix it. It is no longer under warranty.
  2. You have, of course, checked with with a set of known-to-be-good
    headphones? A broken cord wire in, or near the _plug_ of the headphones
    would be my first guess, My second guess is a broken solder joint
    on one of the connections of the on-board headphone _jack_. A final
    guess would be a defective headphone jack, itself.
    Do the speakers shut down when you plug the headphones in?
    I won't see your Google followup. But, maybe someone else will help
    if you supply further innformation.
    Jonesy
  3. rb
    rb Guest
    Might check to see if it is muted in software or
    disabled.
  4. Jess
    Jess Guest
    I have tried with multiple known working headphones. If it is either a
    broken solder joint, or one of the connections of the on-board
    headphone jack, or if the headphone jack is defective, do you know how
    I would be able to find out if it was either of those cases?
    Thanks for your response
  5. Jess
    Jess Guest
    How do I check that?
