C
Chiron
Except, perhaps, to hone one's flaming skills?
Good point; though it seems these skills are sufficiently developed in
this NG.
It's just barely possible that we went to different universities.
Still on the meds I see?
Putting all your bull shit aside, I don't see you as much of a prize
winner, unless you want to count on how much of ass you really are. And
take my word for it, you are an ass. I doubt very much there are many
here that would say otherwise in your behalf.
As far as JF being a hack? I've seen more material come out of him
that would actually work with plenty of help behind it to support those
that are interested. You on the other hand would rather sit there in
your natural domain and make an ass out of yourself. And you do that
very well. Must be one of your strong points.
Maybe JF hasn't had technical schooling in this subject, as "I" and
many others here, have however, I can say that his offerings are much
more interesting to look at rather than your material, which is most of
nothing.
As for myself, You may perceive me as a hack, most likely because you
yourself just assume it is safer that way. You know, just follow the
sheep. Well, you are one of the sheep. I doubt if you could even
truly be able to identify who is and what constitutes a hack/hacker.
What's up, KRW?
You seem unusually contentious this evening.
It's unusual.
This whole thread got out of hand pretty quickly for
a subject that could have been handled with one sentence.
Then a couple more if phase angle needed to be addressed.
No, but the voltage can.
Actually, that was what my vague wonderings were trying to get at. I
remembered that RMS had *something* to do with values going negative; but
I couldn't remember the details. Of course, what I was groping for only
applied to the values that tended to average out to zero, so I was still
pretty wide of the mark... Oh, well.
It's kind of strange to find pedantry in an electronics group. Back in
the day (late seventies, early eighties) we were happy if we were within
10% of reality.
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
He's right and you are wrong. It all depends on the load. In an AC
circuit, with a purely resistive load, VA = Watts. The power factor is
one Hundred percent.
That power factor percentage is just another name for the cosine of
the angle between VA and Watts. No angle = Cos (0) = 1 = 100 percent.
If it were a purely inductive load, the power factor would be Cos (90)
= 0
It's when the load gives you a reactive power triangle that you get
watts on the bottom, VAR (reactive) going vertical and VA on the
hypotenuse.
You may be confusing RMS values for PF.
Indeed. That's the point. Voltage squared => power.
Some use pedantry to attempt to show how "brilliant" they are. It's one
of Field's trademarks.
Are you saying that voltage squared *equals* power? Because if so, it
doesn't.
But what are you saying then? I don't recognize the symbol => - or at
least, I don't know what it is intended to represent.
Implies.
My question was originally about why power couldn't have an RMS value.
Someone said it couldn't happen. Someone else said that the calculation
could be performed, but that it had no physical meaning.
Upon investigation, I found that the calculation can be performed, and
that the result (RMS power) has a physical meaning. I also found that
this meaning isn't particularly useful, which is probably what people
were trying to say.
IIRC, the word "pedant" has the same root as the word "pederasty."
Maybe you ought to get some anger management help before you go
apoplectic, huh?
When I post something technical which is non-trivial I usually show my
work in an effort to more efficaciously communicate the factual nature
of the work, while you seem to revel in nothing but name-calling and
blather.
You wrote: "Voltage squared => power" which reads: "Voltage squared is
equal to or greater than power" which is, of course, nonsense.
Par for the course, though.
In this group, where there are no stupid questions and noobs often ask
questions which indicate their lack of knowledge, what might be
considered pedantry may in actuality be the presentation of subject
matter with enough accuracy and attention to detail to allow them to
learn something.
krw seems to resent - well, just about everything - so he comes
through, true to form, sowing discord and spewing vitriol at every
opportunity.
Dionaea muscipula considers it a matter of life and death.
I phrased it as a question, not as a statement. The reason I did thisI did *NOT* say that. Stop doing a Fields. All things equal, power is
proportional to voltage squared. Voltage squared (divided by
resistance) gets you power.
OK. What you wrote is not mathematically accurate, but that's a wholeImplies.
...and I answered, it can. You can RMS the number of shoes you can see
but it's rather meaningless. The RMS values of voltage and current have
meaning because (relative, for the pendants out there) power can be
inferred from them. Squaring power gets you nothing useful so RMS power
is equally useless.
I said that. Of course you can do the calculation but you can take the
RMS of sneakers, too.
Nonsense. What "physical meaning" did you discover that RMS power has?
