Computer controlled prison neck thingy, a waterproof sealed unit that goes around the neck of every prison inmate with a small LED to indicate it needs charging (solid means do it, flashing means you in big trouble if you don't charge) maybe the prison inmate can sit in a chair and inductively charge the device from wireless power points... if they refuse to do so they get put in soletary confinement for 30 days ..
Anyway on the sealed unit there's a water proof button, on the neck side are 2 electrodes...
Press the button, it sends out a broadcast for 5 seconds or so (programmed) using cheap micro controllers and radio transmits a low radio power range of a radius of 1m. The prison guards can do say 10m radius range with little remote controls
Anyway the prison inmate is in the middle of a kicking or someone is being knifed, the inmate can press his button tazering all of the inmates of 1m for 5 seconds, the beauty is that it can't be abused without abusing yourself and i really don't think people will like you all that much for pressing the button
Would it work? Could it work?
