D
Daniel Kelly \(AKA Jack\)
I'm in the process of building some PCBs based around a handful of surface
mount ICs. I don't have much experience soldering SMD components but the
ICs I want are only available as SMDs. So my question is: should I keep the
PCBs exclusively SMD or mix SMD and through-hole components? As I see it,
the pros and cons for an Exclusively SMD design are:
Pros
- Elegant PCB
- Can mount the PCB very close to the base of the container because there
will only be components on one side
- It'll impress my friends!
Cons
- I'm worried about soldering SMDs. Some of those capacitors are damn
small!
Is this about right?
Should I stop worrying about soldering SMD capacitors and resistors?
Jack
Pros
- Elegant PCB
Cons
small!
Jack
