D
Doug Whitman
I am installing a VHF radio in a 1971 Venture 21. I am handy, and wan
to make my own antenna (mostly, so I can easily repair it whenever i
gets whacked on the trailer). I have read some helpful posts (Larr
and Gary) on this forum which have generated some followup questions.
Using a borrowed SWR meter, I tested the old coax and antenna, an
promptly threw them in the trash. I made a 1/4 wavelength antenna
which worked so well, I am thinking about making it permanent. M
questions are related to this idea.
I understand the advantages of using a 3 dB antenna on a sailboat. I
this 1/4 wave whip, giving the same donut pattern as the commercial
dB antennas?
Is there any advantage in making the whip the same gauge wire as th
center conductor of the COAX?
I can easily make some ground radials at any angle. Would this improv
the transmission pattern?
Marine antennas have gain ratings such as 3 dB, 6dB. What are thes
numbers based on? What would be a 0 dB marine antenna?
I understand the basic fiberglass antenna is a vertical 1/2 wavelengt
dipole with a 1/4 wavelength whip above and a 1/4 wavelength coaxia
tube below surrounding the transmission line. I am running m
transmission line up the inside of my mast, so in a sense, I alread
have a 25 foot coaxial element (fed from the top and grounded at th
bottom) with a 18 inch whip element above. This seems like a usefu
configuration, but I suspect I am missing something.
Comments?
Dou
dB antennas?
Comments?
Dou
