B
[email protected]
Hi folks,
Pardon me for barging in and jumping in with a question but I need to
make a bunch (73) of solenoids for an organ conversion project that I
am into.
Here are the design requirements:
diameter of solenoid .75"
Length -- 2 to 3"
Piston -- .25"
Piston throw -- .375 - .5 "
Piston force about 8 oz.
Stroke type -- Push
supply voltage 12-24 vdc
supply current -- whatever is needed
I have found that I can make some bobbins that are a perfect size from
Bic ballpoint shafts and nylon washers for the ends so that would give
me an inside diameter of the coil of just a shade over .25"
Now the question: Could someone point to where I might find a web
resource page where I can find the neccessary information as to the
best wire gauge to use and then number of turns I should use? A
pointer to an .xls spreadsheet would be *great*!
Or a web page where solenoid design is discussed would also be
wonderful.
Many thanks in advance
Bill
BTW, I am converting an old reed organ to MIDI control and these
solenoids will control the opening of the valves of the organ.
Thanks again
am into.
Length -- 2 to 3"
Piston -- .25"
Stroke type -- Push
wonderful.
Bill
Thanks again
