nyancatvsghosthead
- Jan 7, 2012
- 117
- Joined
- Jan 7, 2012
- Messages
- 117
Also, do you want me to take dimmer photos? That would be buy perfecto. Thanks.
I know, I am
The diode won't work if it is connected in reverse. I think the only way to tell from looking at the LED is that the longer lead is the anode (+ end) and the shorter lead is the cathode (- end). So that would mean the longer lead goes in H9 and the shorter lead on the blue bar. (I didn't get that backward, did I guys??)
If the pushbutton isn't a waste of time I want to buy one, but is there any way of doing this w/o it? If not I don't want to waste my time hopelessly trying to reinvent the wheel. Thank you for the advice.
which one looks like it would work best to you?
I put a wire in substitute of the pushbutton and nothing happened. Does that not matter?
You have made what appears to be a correct decision.I think that might mean that a new pushbutton is a waste of time, but I don't want to disobey proper advice. I basically inserted a wire and plugged it in. I'm wondering, is there a way to test whether or not it would work without a pushbutton?
Yes, just above I suggest using 2 wires in place of the switch and touching the bare ends together as a substitute for pushing a switch.Is that possible?
Also, I am starting to think that I should change the amps because you said that it only pro dues good illumination at 1 mA. How to I change that? Do I have the wrong capacitor or something?
