Categories
Platforms
Content
Yes it's something like that,I've checked against the grid and used cursor measurement as well as scopes auto measure, having trouble picturing it. Is the Vrms only calculated on 1/2 the cycle ? Must be! Thanks..240vac RMS , peak = 240x1.414 = 339.
Peak to Peak = 339x2.
M.
Thanks, don't worry I'm very careful.Measuring the mains with your oscilloscope is potentially dangerous.
Please be careful
As above, most of it is the difference between peak and peak-to-peak. Some of it might be noise.
If the scope has a vertical channel bandwidth limit function, set it to its lowest corner frequency.
Get a 0.1 uF, 250 Vac, X, X2, or Y rated capacitor and connect it directly across the measurement point (scope probe tip to ground lead) with the shortest possible leads.
No warranties expressed or implied - try not to kill yourself.
ak
I've got it sussed now thanks to all repliers. David.Vpeak is the max voltage anywhere in 1/2 cycle, measured with respect to the waveform centerpoint. Vpeak-to-peak is measured between the max positive value in a positive half-cycle and the max negative value in a negative half-cycle. Vrms is calculated using a full cycle.
ak
