Mains powered outdoor delay switch
Discussion in 'General Electronics' started by PCPaul, May 28, 2008.
  1. PCPaul
    PCPaul Guest
    Since pneumatic or mechanical delay switches with outdoor fitting kits
    are extortionately expensive, I was wondering if anyone had a good
    circuit for making my own...
    Ideally a single button press would start a delay timer that activates a
    light for a few minutes (to light the way from the garage to the house).
    I'm happy enough with digital electronics but my analogue is weak.. it
    seems like there should be a way to use mains only for this, with a triac
    or SCR to switch the load (<1000W) and some sort of rectified feed to a
    CR circuit to do the timing. I'm sure there must be a better way...
    The issue of it being outdoors (basically replacing a dead pneumatic
    weatherproof switch) is also a problem, but making a sealed rainproof box
    with a suitably rated momentary switch shouldn't be too difficult.
    Any ideas?
    (I've seen the motorised timers in an earlier thread but they were 110V
    and in the US - I'm in the UK on 240V 50Hz).
  2. neon
    neon
    1,325
    Oct 21, 2006
    replace the switch with a reed switch or optical isolator. so on a rainy day or foggy day you don't kill yourself.
