Magnitude Comparators
M
Michael
I'm working on a school project where I need to compare 16bits (4 BCD
values) from a CMOS logic system and need alternative ways of doing it.
So far I've got 4 cascaded 4063 bit comparators, ADC conversion but I'm
struggling for a third. Can anyone suggest a method?
I was thinking about using a CMOS compatible 74 series bit comparator but
it's not really that different from the 4063 method......
Cheers,
Michael
S
Stephen J. Rush
but it's not really that different from the 4063 method......
A microcontroller running a short loop? Some of the Atmel 8-bit
microcontrollers are absurdly cheap.
C
Chris
Cheers,
Michael
Hi, Michael. You might get some homework points for variety by
latching the two 16-bit numbers into shift registers, then serially
comparing the bits, starting with the most significant. First non-
equal (discrete logic here) sets the greater-than or less than flip-
flop. which locks the other one out. Both flip flops reset on the
latch signal.
If it were an 8 X 8 or even a 12 X 12 compare you could use one PROM.
You might offer a suggestion that you could compare the first byte
using a PROM, then if equal, compare the second byte using the same
PROM or a second PROM if you want to stay away from latching and
sequential logic.
Someone else has mentioned using a PIC, which is a valid one-chip
solution.
Not too many ways to compare two numbers except to compare them, I
guess.
Good luck
Chris
