Magnifying light voltages
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Thanks Bertus. Interesting. The diopter is 125mm dia. They have a 5" one there but no way to guarantee that it will fit. The fit is quite restricted. Before I take that chance I'll rather build something with a bunch of led's
Martaine2005
May 12, 2015
4,953
May 12, 2015
4,953
Well, interesting results.
One meter giving me DC and the other AC.
R1 330V. 23V.
R2 23V. 7.5V.
D5 23V. 7.5V.
C5 0V 7.2V.
The DC for D5, C5 and R2 was between 2.6VDC and 3.42VDC on the auto range Fluke.
I don’t think I am getting reliable results here. But I won’t lick my finger to check!
These inverters shouldn’t really be powered without a load. So I kept my tests short and sweet.
Martin
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Thanks a mil Martin
That helps a lot. So R1 could be a problem. Colours green/brown/white and gold. That gives me 51MΩ. Correct?
Pretty sure I don't have that in my stash.My one dmm reads 10MΩ but got nothing else to corroberate with
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
On closer investigation green/brown/yellow so 0.51MΩ
bertus
Nov 8, 2019
3,330
Nov 8, 2019
3,330
Hello,
When it is 510 K, an 470 K will likely work.
Bertus
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Thanks Bertus
What I am trying to get around is R1 I assume is there to drop the voltage from 330 V to 23V. In my case it drops the voltage to 137V. So my reasoning says my R1's resistance is too low. But measuring it in circuit it measures about 500k. So why is it not dropping the voltage.Or could C5 be causing the trouble?
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Can you measure a resistors resistance while it is in a powered up circuit?
bertus
Nov 8, 2019
3,330
Nov 8, 2019
3,330
Hello,
I have tried to make a "handdrawn" schematic in Kolourpaint.
Can you fill in some values?
I have used this public domain sheet for the components to copy and paste:
Bertus
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Bertus
Thats fantastic
But I'm battling to ID the components with any certainty. I have done some updating on this layout. Please can you number the components on your layout as per this sheet. I have highlighted the component numbers
I cant ID D5 but it reads 510 in diode mode
My apologies
bertus
Nov 8, 2019
3,330
Nov 8, 2019
3,330
Hello,
You are still missing some parts:
Here is what I can see to annotate:
I do not see a R3.
Bertus
bertus
Nov 8, 2019
3,330
Nov 8, 2019
3,330
Hello,
Did you also identify the capacitor between the DB3 and the line 0?
It is a green one on the picture.
Bertus
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Apologies Sir Bertus. Fortunate that I did not take up electronics as a profession:eek:
I hope this works now
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Oh and R4 was actually R3 and the new R4 is to the right and below Q1
bertus
Nov 8, 2019
3,330
Nov 8, 2019
3,330
Hello,
Then this could be the schematic:
Do you also have some values?
Bertus
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
C5 202J 0.002uf ?
D5 ?
C4 220J
C6 104J 0.00022uf
C7 407J ?
D6 & D7 FR107S
bertus
Nov 8, 2019
3,330
Nov 8, 2019
3,330
Hello,
When I look at the schematic I made, it looks a lot like the luxtek 8W, from the site I gave on page 1:
One of the differences is that D2 is not there and there are diodes on the basises of the transistors.
I don't get the value of C7 407j ?, that would be very large.
Bertus
