M
Mark rainess
I am building a machine that uses a microwave oven. I need a simple and
cheap way to reliably determine 1) that the magnetron is operating, and
2) that the oven cavity is not empty.
My first attempt was a diode RF sensor on a board mounted outside the
cavity with a short probe projecting inside through a hole. The food
item being heated moves relative to the probe and causes the response to
increase and decrease as it acts on the E field. When I see the changing
response I know the magnetron is working and the oven is not empty. This
works fine if the food is by itself; but, the food rests on ceramic
which moves. The ceramic material influences the E field to a large
degree and makes it impossible to detect the food item. I can't
eliminate the ceramic or change to another material. It seems I need an
entirely different approach.
If I put two RF probes in the waveguide spaced one-quarter wavelength
apart, I think the phase relationship between the two probes will change
when the oven is empty.
I want to avoid the expense of adding a secondary waveguide in order to
make a directional coupler.
Does anyone have an idea for a simple cheap way to detect that the oven
is empty.
Mark
is empty.
Mark
