magnetron characteristics?
Discussion in 'Electronic Repair' started by poster, Feb 28, 2009.
  1. poster
    poster Guest
    Is there some place to look up Microwave
    Magnetron Sharp 2M240G-A251 characteristics-size and is it 1250watt,
    2450MHz type
    (i.e can it be replacement for Magnetron Sharp 2m237-a064 )?
  2. James
    James Guest
  3. James
    James Guest
  4. Guest
    This is Daniel from Main Electronic Supplies, I was searching the web
    trying to get some specs. on a magnetron in order to find a sub number
    in our stock. I was very pleased to see a reference to us in this
    form. We do try our best.
    Thanks James
    Daniel
  5. James
    James Guest
    great, Daniel !! Yes, your company name came up in a Google search when
    I was trying to help another user. The person who made the original post
    never commented again, so I hope that he got the information.
    Some folks post questions here and either never come back to the forum, or
    never say thanks.
    Good luck !!
    James
  6. Franc Zabkar
    Franc Zabkar Guest
    Some will thank you personally via email. IMO that's possibly a better
    way to do it, unless there is something to add to the original post.
    - Franc Zabkar
  7. Smitty Two
    Smitty Two Guest
    Huh? Who uses a real email on usenet?
  8. GregS
    GregS Guest
    me
  9. GregS
    GregS Guest
  10. I do. What's the danger, a bit more spam?
  11. Jerry Peters
    Jerry Peters Guest
    A bit more spam? When I got hit with Swen I had several *thousand*
    spam emails. That's when I stopped providing a real email address.
    Jerry
  12. Why heck, I'm not afraid to put my E-mail address
    out there, send me all the Spam you like though
    sometimes I prefer Armour Treet.
    TDD
  13. Guest
    The answer is no, there is not some place. Like any part, you pick
    the magnetron you want to use based on the specs of the product and
    look at the datasheet of the replacement to see if it'll do the job.
  14. GregS
    GregS Guest
    I think this email has perked up in spam. I don't see it from another
    email cause the filter gets rid of 80-90 % of the mail which is spam.
    Getting back to magnetrons, I am trying to fix a microwave.
    The diode was replaced and the transformer.
    Far as I can tell the cap is good and the diode is still good.
    Checked filament on magnetron of about 4 volts. If there
    is supposed to be visable light, there is none from the filaments.
    I nedd to make sure of the cap and diode, but
    anu suggestions are wanted.
    I took the microwave home my brother has been replacing
    those parts. I put in some water and after 20-30 secs the water was heating.
    After that NOTHING heating up. Pretty much sounds the same.
  15. poster
    poster Guest
    check fast fuse and protectiive diode first
    back to my problem -3.3v,2450mhz seems to be standard so need
    information if 7-800w magnetrons(4.1kv) or 5-650w(3.8kv) type usually
    goes into in/out power-1250/600w ovens?
    Can someone please open&read the power/mag. designation off some older
    microwave.
    Thanks in advance
  16. GregS
    GregS Guest
    Who you talking to ?
  17. poster
    poster Guest
    regrettably no data anywhere on 2m237(that is rv-mza064wreo) but if
    microwave's high voltage trafo rtrna177 is indeed at918
    (?cannot be certain without measuring filament voltage however
    www.gallawa.com/microtech/xformer.html says it is not a good idea)
    than it outputs 4.35/2 kv and 3.15v,which indicates magnetron
