Magnetism Strenght
Discussion in 'Electronic Basics' started by Camilo Andres Gil Cardona, Aug 17, 2003.
  1. Hi everybody! i need to know which is the equation for calculate the
    atraction or repulsion strenght of a magnetic field from a natural
    magnet or a coil, preferably the coil(repulsion when equal poles are
    confronted)... other thing, ¿Does increase the magnetic atraction when
    two opposite poles are confroted that when a single pole (of a magnet
    or coil) atracts a ferromagnetic material?! beforehand, thanks for any
    answer!
  2. To get started go to http://152.66.73.137/research/field/mam.html
    and then do some google searching on your own. Your questions are kind of
    "loaded."
  3. In the most general terms, the force produced by any magnetic circuit
    depends on how much the total flux varies with the motion of the parts
    in question. If the flux changes more per unit of motion, the force
    is higher. Since the is no limit ot the geometric choices you have,
    there can be no simple mathematical rule to predict the force. The
    whole flux path and all its geometry has to be modeled.
  4. Excellent answer John, but for the laymen here lets complicate things
    just a bit as a simple puzzle.
    For the purposes of the puzzle, let's assume that we have a large "C"
    shaped magnet with a 3/4" spacing between its pole faces.
    The questions:
    1. (easy) I we hold a 1/4" thick plate of mild iron midway between the
    ple faces, when we release it will it be attracted to the N pole or
    the S pole of the magnet? In other words, in which direction is the
    magnetic attraction?
    2. (requires a bit more thought) Assuming again that we hold the iron
    plate midway between the pole pieces, the magnetic flux path is though
    the magnet itself, then though a 1/4" airgap, through the iron plate,
    though another 1/4" air gap and then back into the body of the magnet
    itself. Why would the net flux be different when the iron plate is
    attracted to and in contact with one of the magnet's pole pieces,
    since the reluctance of the magnetic path appears to be the same in
    both cases? (The magnetic flux has to change for magnetic attraction
    to take place.)
    I suppose you could call these brain teasers, but I do know of at
    least one graduate school admission exam in which question 2 appeared.
    Have fun.
    Harry C.
  5. Good one. But what is the shape of the 1/4" thick plate? Knowing the
    phase of the moon might help too. ;-)
    Why would you assume the reluctance is the same in both cases, unless
    you assumed the flux lines are parallel between the pole pieces, and
    this condition is unaffected by the presence of the iron plate.
    But that would be a silly pair of assumptions. :)
