Put it under load and see what it takes to overcome that load and spin... I can only guess, but I suspect that you will find it will need to be HUGE to handle any real load... And at that size when is it practical?
For example if you need a house sized device (or even a room sized device) to transfer 100 ft/lbs of torque vs the traditional baseball sized metal gear tranny that does it fine, what application would this benefit and be practical?
That big it can't do anything useful?! Wow... Then barry this bad boy under the ground it isn't useful then hahaha
It can't carry anything I doubt It can lift a human being off the ground the gears will slip and that will be terribly bad lol.
So that torque is the force of pushing things that are heavy huh? Now I understand things even more !
