Magnetic path length of regular old bar core inductor?
I've scoured the interwebz for information on inductor design. I want
to construct an inductor by basically wrapping wire around a round bar
of iron. My problem? What value do I use for magnet path length in
my calculations? I assume since the flield will be exiting the bar
ends and wrapping around in air back to the opposite pole it would not
be as simple as the length of the bar.
Every design example I've run across assumes a closed box section core
or torroid. What ever happened to a simple bar core inductor?
Any useful web links or information you could provide would be useful.
Thank you,
Gerb
Jon Slaughter
Thank you,
Gerb
http://en.wikipedia.org/wiki/Reluctance
Thank you for the informative reading materials. However, I still did
not find what I am looking for. However, I think I have my answer if
my assumptions are correct.
May I assume that I will not gain much benefit of using a core by
winding wire around a solid flat bar core that is open at each end?
Am I correct in assuming this essentially will be equivalent to an air
core inductor since the magnetic path is not closed? I've read that
some improvement in inductance occurs by wrapping wire around a bar
but nothing quantifies this or offers a means to calculate.
Thank you,
Gerb
Jon Slaughter
the magnetic path takes the path of least resistance. If you have an open
bar then the magnetic field will have to travel back through the air to
complete the closed path. If the bar is closed then it doesn't have to.
You need to add the reluctances up of each path to get the total reluctance.
Reluctance is equivalent to resistance in electricity.
The problem with a bar is to determine the path through the air. Suppose you
use a closed core but then remove just a small slice. In the slice it is air
so you compute it's reluctance and add it to the reluctance of the other.
i.e.,
R1 = (l - dx)/u0/ur1/A and R2 = dx/u0/ur2/A
Although A in R2 is an approximation since it will actually be slightly
larger since the field will fringe out a bit.
But with a straight bar you end with dx being large and uncertain along with
A not being known. The reason being is that the field will "spread out"
throughout the air.
So we have something like
R1 = L1/u0/ur1/A1 and R2 = L2/u0/ur2/A2
and the total reluctance is R1 + R2. Determining R2 theoretically is
difficult but you can easily measure it since R1 is known.
i.e.
R = R1 + R2 = mmf/phi
Now if your really serious you could solve Maxewells equations to get the
solution but seems like a lot of work than just measuring it. (I'd imagine
that someone had to have solved the thing before)
