M
m II
I have no experience using the programs available for finite element
analysis and don't have the time to learn how to use one.. If someone
experienced with their use could run a simulation, it would be of great
benefit.
I have a microwave oven transformer of 1000W rating.
I would like to remove the "I" part of the core, leaving the "E"
segment, along with the windings.
What I am interested in finding out is what happens when a permanent
magnet pole is moved past the centre leg of the core.
What is the change when a metallic return path to the back of the magnet
is provided? Think of a steel strip with the magnet in the centre. This
strip would sweep across the three legs of the core.
What change with a large disc magnet in the centre of the strip and two
smaller magnets with flipped polarities on the outer ends? I'm assuming
the air gaps remain the same.
Any units of comparison would be great, as it's the *relative* output
changes in the windings that I'm interested in. There has to be a way of
simulating this on the computer. I don't want to build the project in
real life until I can see some promise of success. This coil/core would
become 1/9 of a wind turbine alternator and be rectified for use.
One of those neat multicoloured flux flow graphics would be interesting.
mike
benefit.
mike
