Magnavox TV colors went crazy
Discussion in 'Electronic Repair' started by labrick, Dec 1, 2003.
  1. labrick
    labrick Guest
    Our Magnavox TV (about 13 years old) has this problem:
    Something went wrong with the color, I'll try to explain it.It's as if
    someone is holding a see thru color screen in front of the picture and
    the colors of the screen are very psyco-delic. Kind of a neon green
    oval in the middle, surrounded by a hot pink, surrounded by a blue and
    then surrounded by a mix of green and brown. So the reception is good,
    the colors are very crazy.
    It's a 27" monitor.
    There was a definite sizzle or crackle the day I turned it on and it
    did this.
    There's a place in town that does free estimates, but I thought I'd
    look around the internet and see what I could find out about this
    problem before we drag this big thing around town. Will it be
    expensive? Should we look for a new TV vs cost of repair?
    Actually our living room TV is goofy too, I'll post seperately about
    that (RCA TV left & right sides have black area).
    Thanks!
  2. Failure in the degaussing circuit...
    me
  3. Patch
    Patch Guest
    Sounds like the picture tube has become magnetized. Probably the
    auto-degausser has crapped out. Call a service tech.
  4. James Sweet
    James Sweet Guest
    Your degaussing circuit failed, sounds like the thermistor burned up, part
    is a few bucks, figure an hour of labor at most, worth getting fixed.
  5. Chaos Master
    Chaos Master Guest
    labrick() slammed into the keyboard with a 100-lbs hammer:
    Probably the degaussing circuit has failed. Nothing too complicated for an
    experienced tech, and worth the repair.
