Magnavox 9P6040C104 problem
Discussion in 'Electronic Repair' started by Max, Nov 16, 2007.
  1. Max
    Max Guest
    Hi Working on this rear projection tv Find out that blue lens has dirt
    inside and need replace the coolant.Drain coolant but reliazed that dirt
    still between lens and crt.To remove the lens I need torx key because
    there is 4 sticks with torx on the end.Where can I find the torx key or
    socket.I went to SEARS they don't have it just only for torx screws not
    for sticks like this.Please help.Also when I turn the cooling access cap
    I accidently broken it.Where can I find or order new cap.Thanks
  2. PeterD
    PeterD Guest
    Torx E wrenchs are at most auto-parts stores.
  3. Bill S.
    Bill S. Guest
    These are inverse (aka external) torx and go by E sizes instead
    of T. I bought a set from SK tools for too much money, but
    they fit properly.
    I hate when that happens. If it's the bayonnet style plug that
    takes 1/4 turn, I don't have any. Might still be available from
    Philips or someone like partstore.com if you can find a part#.
  4. Max
    Max Guest
    Thanks a lot for your help
