M5450B7 - 34output LED driver
Discussion in 'Electronic Basics' started by Jan Nielsen, Jun 22, 2007.
  1. Jan Nielsen
    Jan Nielsen Guest
    DataSheet:
    http://www.ortodoxism.ro/datasheets/SGSThomsonMicroelectronics/mXqrr.pdf
    I have a few of these and is trying to get them to work, sofar with no
    success.
    I have made a voltage divider with a 300ohm resistor and sent that to
    brightness control.
    Added a 0.47uf cap to the divider, and the +/- legs of the chip.
    Added +/- where needed (pin 1-20)
    Connected the data and clock to a picaxe.
    Not sure about enable if it should be low or high, but have tried both.
    With enable low there is a small change when the picaxe turn off a
    input, but theres only <1V on the output, when theres 5.1V on the input,
    that wont drive anything.
    The test code for the picaxe is here, not sure if it works either ofcause.
    #picaxe 18x
    symbol dataout = 0
    symbol clock = 1
    do
    SerTxd("OFF",CR,LF )
    HIGH dataout
    HIGH clock
    PAUSE 4
    LOW clock
    for b0=1 to 36
    LOW dataout
    HIGH clock
    PAUSE 4
    LOW clock
    next
    pause 3000
    SerTxd("ON",CR,LF )
    HIGH dataout
    HIGH clock
    PAUSE 4
    LOW clock
    for b0=1 to 36
    HIGH dataout
    HIGH clock
    PAUSE 4
    LOW clock
    next
    pause 3000
    loop
    -done-
    Its an old chip I know, and I werent able to find any exsamples on its
    use, except the datasheet, which as far as I can tell dont even say if
    enable needs to be low or high.
    Anyone know why it dont work ?
    /Jan
Similar Threads
Loading...
