LXI series tv channel 4 issue
Discussion in 'Electronic Repair' started by docfl, Apr 10, 2007.
  1. docfl
    docfl Guest
    Our cable box uses channel 3 with no problem. My dvd player uses
    channel 4, big problem. I dont have the remote, however I have tried
    to auto scan channel and tried both on air and cable using the menu
    button on the front. I still cannot get the tv to change channel to
    use the dvd player. We had it set at one time and then I messed it up
    and am trying to get it back.
    I did a google search and tried the suggestions I found without
    success. Any help would be appreciated.
    I even have tried to use the universal remote from the cable box and
    can get it to turn on and off and volume control, still no luck with
    the channels.
    Thanks for the help
    Docfl
  2. Guest
    You need to try a different code with your cable box universal remote.
    or ....
    Go to WalMart, KMart, Radio Shack, etc...... get a cheap universal
    remote control, program it for your specific television, and then you
    can "enter" your desired channels with the numeric keypad on the
    remote. No more than $9.99 ..... sometimes as little as $4.99 on
    sale.
    electricitym
