lvds dac
Discussion in 'Electronic Design' started by [email protected], Dec 27, 2008.
  1. Guest
    I am looking to get 16-channels of 50 - 100 Msps 8-bit D/A in
    the most minimum of pcb real estate. Usually this means cutting down
    on i/o pin count. There are a lot of serial lvds a/d converters, some
    with 8 or 16 channels that would work perfectly except in reverse. For
    example the AD9222. Does anyone know of any parts that would work
    well?
    Tia, Jon Pry
  2. Guest
    How about a gate driver?
  3. Guest
    Woops, meant a source driver, same difference.
    http://www.advancedsilicon.com/web/uploads/media/ASTLC5101A_v1.0_03.pdf
    Basically the wacko chips that drive all the sub-pixels on a LCD panel.
  4. Guest
