Luxeon star driver
Discussion in 'Electronic Design' started by Mike, Sep 28, 2005.
  1. Mike
    Mike Guest
    Is there a diagram out there to drive a Luxeon III star from 12V without
    having to use a huge limiting resistor?
    THE BOULDER PLEDGE
    "Under no circumstances will I ever purchase anything offered to me as the
    result of an unsolicited e-mail message. Nor will I forward chainletters,
    petitions, mass mailings, or virus warnings to large numbers of others. This
    is my contribution to the survival of the online community."
  2. ehsjr
    ehsjr Guest
    +12 ----| 7805 |---[2R]--- Vout to Luxeon, 650 mA
    Gnd --------+
    Figuring Vf at 3.7 volts, 2 ohms will limit current to
    650 mA, so a 2 watt resistor will do. The 7805 can
    go up to 1 amp, and needs a heat sink. It will dissipate
    up to ~7 watts. If you want to go "full bore" (>1A), use
    a different circuit:
    ------- 2W
    +12 ----| LM317 |---+---[1R]--- Vout to Luxeon
    | [240R]1/2W
    +-------+---[2.2K]------+
    | 1/2W |
    [810R] 1/2W [POT] 5K
    | 1/2W |
    Gnd --------+-----------[120R]------+
    The above will allow you to vary the current to the Luxeon
    from about 670 mA to 1.34 amps.
    You could use a 2 watt one ohm limiting resistor, but it will
    dissipate about 1.4 watts, so a little higher wattage gives a
    wider margin and is desireable. The other resistors are 1/2 watt.
    The LM317 will need to dissipate ~ 10 watts, so a heat sink
    is needed.
    Ed
  3. René
    René Guest
    I would get a $0.40 MC34063, a a well chosen inductor, and make a low
    dissipation current source. ~600 mA without external boost fet /
    transistor is achievable.
    Beats huge heatsinks etc. Including the ~ 50 uH inductor it would be
    cheaper too I guess. My 0.02
