I have some work to do to find the best way to sink these things, as I need
to get 9 LED's in very close proximity. I'm thinking copper with a 100um
layer of insulation. Some kind of epoxy painy? I'm also considering
glueing the LED emitters directly to copper rods which will
terminate into another block of copper or aluminum.
greg
If you use Stars, the heatsink is electrically neutral so they can go
directly on the heatsink. Use heatsink grease. With emitters,
secure them with a good thermal epoxy like Omegabond 101. In either
case, your heatsink is going to need enough area or forced air cooling
or both to keep the sink at acceptable temperature while dissipating
45 watts or so. Check their website for app notes on thermal
management and maximum acceptable package operating temperatures.
