Lubricant for a wierd problem
Discussion in 'Electronic Basics' started by siliconmike, Jun 23, 2005.
  1. siliconmike
    siliconmike Guest
    I have a pcb with 10 electrical gold plated contacts in a single line
    with 5 mil isolation between them.
    At any time, a small gold plated copper part "C" makes a very *light*
    contact with only one of the contacts.
    A *weak* force is responsible to move C over the range of contacts.
    Is there some lubricant I can apply on the contacts to reduce the
    friction between C and the contacts?
    Please don't advise to change this setup as nothing can be changed, for
    certain reasons.
    Mike
  2. Alan Adrian
    Alan Adrian Guest
    This can be done with math... but quantities such as *weak* and *light*
    won't get you (or anyone else) there...
    Al...
  3. Chris Berry
    Chris Berry Guest
    Graphite?
    cb
  4. Tom Biasi
    Tom Biasi Guest
    Chris, graphite is conductive.
  5. Yukio YANO
    Yukio YANO Guest
    POLYPHENYLETHER
    example SANTOVAC 5
    Found in some "Contact Kleaners" as "with PPE"
    Extremely Low Vapour Pressure, very stable, inert, great lubricant,
    expensive, "same price range as Gold !"
    Also available as a "High performance Ulta high Vacuum Grease "Fomblin"
    Yukio YANO
  6. The Phantom
    The Phantom Guest
    There is a product called "Gold Guard", whose active ingredient is polyphenylether, which
    is just for this job.
    http://rocky.digikey.com/scripts/ProductInfo.dll?Site=US&V=75&M=CP420E
  7. CWatters
    CWatters Guest
  8. siliconmike
    siliconmike Guest
    You are wrong. Probably if you had a clue you would have replied /
    guessed a solution like 7 other replies to my message which have been
    of great help.
  9. Chris Berry
    Chris Berry Guest
    That's one reason why I suggested it.
    Not knowing anything about the application itself, it might be a solution.
    cb
  10. Ross Herbert
    Ross Herbert Guest
    Stabilant 22 should do the trick http://www.stabilant.com/techt02h.htm
    While not marketed as either a contact cleaner or lubricant, it does
    do both. Expensive but good.
  11. I have (or had, I should say) a flashlight that I converted over to
    white LEDs. Well, to my surprise, when I shut off the swtch, the LEDs
    continued to glow dimly. I came to the conclusion that the grease they
    used on the slide switch contacts was somewhat conductive. This wasn't
    noticeable on a ragular filament lamp, but the LEDs showed it easily.
    So if you do use a lubricant, make sure it is a good insulator.
