LTspice issue.
Discussion in 'General Electronics Discussion' started by Martaine2005, Jan 22, 2021.
  1. Martaine2005
    Martaine2005
    3,211
    879
    May 12, 2015
    Hi guys n gals,
    Yesterday, I updated LTspice which took over 40 minutes. I hadn’t updated in two years.
    The issue is I can’t ‘snap’ components in place anymore. Meaning the component stays attached to my cursor. Even goes off screen when I try the ‘back’ button.
    I’m sure it’s something silly but was unable to sort it out last night.
    Any ideas before I re-install?
    Ps. No other software updates were done, so laptop is the same as before.
    Martin
  2. Harald Kapp
    10,990
    2,496
    Did you do an update or a clean new install?
    I've experienced issues with updating in some cases, too. A clean install usually helped.
    Just did an update: no issues with snapping components.
  3. Martaine2005
    Martaine2005
    3,211
    879
    May 12, 2015
    It was just an update.
    I think the update is XVII. I can’t remember what the version was before the update.
    I was hoping I did something silly. But perhaps a clean install is required.
    Martin
  4. Harald Kapp
    10,990
    2,496
    Takes usually not much more time than an update. Probably less as the gathering of information about the present installation can be skipped.
    Definitely less than 40 minutes ;)
  5. Martaine2005
    Martaine2005
    3,211
    879
    May 12, 2015
    Thanks Harald, I’ll do a clean install now.
    Martin
  6. Alec_t
    Alec_t
    2,926
    796
    Jul 7, 2015
    In Control Panel/Drafting Options, make sure 'Automatically scroll the view' is disabled.
  7. Martaine2005
    Martaine2005
    3,211
    879
    May 12, 2015
    Thanks Alec, I did a fresh install before you replied.
    All working now.
    Martin
  8. Harald Kapp
    10,990
    2,496
    Too bad. Now we don't know whether it was the installation or the setting ;)
    Glad it works for you.
