C
Chris Carlen
Greetings:
I have the newest LTSpice.
When I use the 1-pole amp, with rail=0, the output can swing to the
supply rails. If rail=1, then it can swing within 1V of the rails.
This makes sense.
But the 2-pole op-amp doesn't work like this. For instance, with a 10V
positive supply and -5V negative supply, and rail=0, the 2-pole op-amp
swings from -3V to 9.8V. This is inconsistent with what seems to be the
intent of the rail parameter, and inconsistent as well with the 1-pole
behavior. Is the 2-pole broken or it is supposed to work differently?
Thanks.
____________________________________
Christopher R. Carlen
Principal Laser/Optical Technologist
Sandia National Laboratories CA USA
[email protected]
This makes sense.
Thanks.
[email protected]
