LT1246 applications
Discussion in 'Electronic Design' started by nvall, Aug 10, 2007.
  1. nvall
    nvall Guest
    Can anyone please help me in using the part LT1246, ie as to how the
    part can be connected in a simple circuit, how to test its working and
    anything related to its working as there are no such things available
    in the data sheet provided by Linear.
  2. Eeyore
    Eeyore Guest
    Why are you looking at using it if you don't know what it can do ?
    Note: "Pin Compatible with UC1842"
    There's no shortage of application circuits for that part.
    Graham
  3. MooseFET
    MooseFET Guest
    The part does just about exacly what the simplified schematic suggests
    it will. The big difference is that it goes insane if you force the
    control voltage (pin 1 IIRC) within about a diode drop of ground.
    Don't do this.
    The "up to 1MHz" is a bit of a stretch too. They get way too hot
    doing that.
