LT1037 packages
Discussion in 'Electronic Design' started by Gregory L. Hansen, Feb 28, 2005.
  1. I was trying to order some LT1037 op-amps, but I don't know which suffix
    to order:
    LT1037ACN8
    LT1037CN8
    LT1037IN8
    The data sheet doesn't say what the differences are. I just want the
    standard used-in-undergrad-lab-classes 741-style 8-pin DIP package.
  2. They are all DIP8 cases. The differenc is noted above.
    Rene
  3. Guest
    They're all DIP-8, just like you want. The other letters are just
    models with different precision. Any 1037 ending in N8 is DIP-8
  4. On Mon, 28 Feb 2005 21:05:25 +0000 (UTC), the renowned
    That's what it's for.
    Here's the data sheet (maybe):
    http://www.linear.com/pc/downloadDo...240?navId=H0,C1,C1154,C1009,C1026,P1213,D2204
    If you read it carefully (and compare various bits of information)
    you'll see that all three above are in plastic DIP package (N8) but
    vary in temperature range and specifications.
    A B C
    LT1037 AC N8 <--- better specs (10uV Vos max etc. etc.),
    commercial temperature range
    LT1037 C N8 <--- cheapest version, loose specs, commercial
    temperature range
    LT1037 I N8 <--- loose specs, industrial temperature range
    A- family
    B- specs and temperature range
    C- package
    Best regards,
    Spehro Pefhany
  5. Cool. Faster response than Linear's tech support, too. And as I learn to
    interpret the data sheet I see the differences are there, e.g. a column
    for LT1037AC and a column for LT1037C.
    Are the different versions manufactured differently, or are they all from
    the same batch, and then tested and graded?
  6. I guess there is one process, then the dies on the wafer are tested,
    then the wafer is cut and the dies are mounted into the cases.
    Rene
