T
Test
I am trying to use LPT port to control a small 5 V relay (Meisei ps-5). The relay
appears to have 1.75 ohm resistance.
I connected the data pin to the + pin of the relay and ground to the gnd pin. No
click. Voltage drops to about 2V. Then I tried with DC power supply at 4.5V
(1.5A). A nice click is audible from the relay.
(Bear with me: I am a newbie) I conclude that LPT is not suppliying enough
current (live and learn!). After googling for some time I am presented with a new
thing that should: a transistor - as in "transistor radio".
This helpful site has a cirquit that fits the bill:
http://www.epanorama.net/circuits/parallel_output.html#relaycontrol
here is it:
Vcc
| __|__
Relay /^\ Diode 1N4002
Coil /---\
4.7K B |/ C
parallel port >-\/\/\/\/---| NPN Transistor: BC547A or 2N2222A
data pi |\ E
| V
parallel port >--------------+
ground pin |
Ground
Above need an extra power supply (Vcc). Is any way to use power (perhaps from
multiple data pins) from the LPT port itself? One pin gives out 0-5V and a few
milliamps. The Meisei relay I have seems to need more.
here is it:
Vcc
| __|__
Coil /---\
4.7K B |/ C
data pi |\ E
| V
ground pin |
Ground
